Help- cylinder wall marks- is it a problem?
Old 01-04-2017, 08:59 PM
Olsen185's Avatar
Olsen185
Olsen185 is offline
Default Help- cylinder wall marks- is it a problem?
Ok here is the deal, I just tore down the motor to add some ported and polished heads. My 107 kit has about 2500 miles so far. When I removed the old heads I noticed some marks on the cylinder walls. The front cylinder seems to have more marks then the rear. Is this something to worry about? The marks can't be felt with a fingernail.
Attached Thumbnails Help- cylinder wall marks- is it a problem?-img_0330.jpg   Help- cylinder wall marks- is it a problem?-img_0334.jpg   Help- cylinder wall marks- is it a problem?-img_0337.jpg
Old 01-04-2017, 11:32 PM
Desertwndrr's Avatar
Desertwndrr
Desertwndrr is offline
Pretty normal. If you can't feel it by fingernail, it doesn't smoke, then run it.
Old 01-05-2017, 06:48 AM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
I think ide be pulling them,torque plateing & checking for out of round & taper,ide also check ring condition.marks like that are defanatley NOT normal
Campy Roadie (01-06-2017)
Old 01-05-2017, 08:28 AM
roussfam's Avatar
roussfam
roussfam is offline
Received 6,744 Likes on 3,511 Posts
Normal and not normal, gotta love getting advice on the Internet. Was it running ok?
Old 01-05-2017, 11:47 AM
Olsen185's Avatar
Olsen185
Olsen185 is offline
Yup bike was running great. Just had some money to burn so I ordered a set of heads.
Old 01-05-2017, 01:19 PM
prodrag1320
just cause its running OK,dosnt mean it shouldn't get looked at.if you drain your oil and its full of metal,but its running OK,your good to go I guess
06 Ultra Classic (01-15-2017)
Old 01-05-2017, 01:27 PM
MURPHCC1's Avatar
MURPHCC1
MURPHCC1 is offline
Received 2,791 Likes on 1,359 Posts
YES.......there is a problem......NOT supposed to look like that.....as to what is wrong...I don't know....not gonna guess.......have it checked!
hvacgaspiping (01-06-2017)
Old 01-05-2017, 01:59 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
You already have it apart, what would the reason be to NOT have it checked? You yourself know there could be an issue thats why you posted a question. A professional , prodrag1320, has given you an opinion that should be valued. Seems silly not to have it checked at this point.
Old 01-05-2017, 02:57 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,259 Likes on 3,629 Posts
The middle pic is disconcerting. 1 and 3 show some ghosting at the cylinder studs and oil drain passage but that is common.. More so on virgin cylinders than ones that have seen a bunch of heat cycles before boring. It's probably more prevalent on the 3.938 bores too. I'd be a little concerned about the cylinder finish.. looks like it was done with too fine a stone.. As the crosshatch is weak. I agree with Kirby, pull them. have them checked..
Gordon61 (01-05-2017)
Old 01-05-2017, 03:08 PM
roussfam's Avatar
roussfam
roussfam is offline
My guess would be no..
You gotta be careful, some people might not recognize sarcasm...
Quick Reply: Help- cylinder wall marks- is it a problem?
