bike will not start
Old 02-14-2017, 01:37 AM
2013superglideseattle's Avatar
2013superglideseattle is offline
Default bike will not start
2017 roadglide special with 5k miles. Well, I went on 5 weeks vacation. I came back home and for some reason I thought about my bike not on battery tender before going away. I went straight to the garage before anything else and sure enough she was not on tender.
Battery totally dead! I took it out and went to HD for a swap. Fortunately, she still under warranty so its free of charge.
Installed new battery and double check connections before starting. I turned ignition to on and everything lights up and shows past 12volts at the gauge. Selected kill start switch to start and heard fuel pump go off. Pressed start button and nothing? No clicking, no sign of starter motor firing up. WTF!
Key fob with me. No fault at the console. Put the bike in gear and rock it. No help. Hold clutch lever while starting still nothing. Put back in neutral and still not starting.
What could go wrong? checked all fuses and all good. Is there anything I missed out?
Old 02-14-2017, 03:00 AM
Harttoo's Avatar
Harttoo
Harttoo is offline
Wow,really bizarre! I would check for codes.Hold trigger switch down while turning ignition on.Step thru codes with trigger switch.Check fob battery.Try to start with security code.
If all else fails have Dealer pick it up.
Old 02-14-2017, 06:21 AM
mjwebb's Avatar
mjwebb
mjwebb is offline
Received 8,543 Likes on 4,431 Posts
is it bone stock or have any electronics been added or modified recently before you left on your trip?
Old 02-14-2017, 06:43 AM
jclax01's Avatar
jclax01
jclax01 is offline
this may sound really simple, but is the run start switch on? I have done that one before.
Old 02-14-2017, 06:54 AM
mjwebb's Avatar
mjwebb
mjwebb is offline
my first thought but he did say he heard the system initialize before flipping the start switch..but yeah, I've done that too
Old 02-14-2017, 07:14 AM
Wmitz's Avatar
Wmitz
Wmitz is offline
Is the neutral light on? Was there a spark when you replaced the battery? I believe there is a reset by turning the ignition on and off x amount of times, check the manual.
Old 02-14-2017, 07:46 AM
sixguns's Avatar
sixguns
sixguns is offline
Received 1,458 Likes on 755 Posts
How many wires/cables connect at the battery? check there.
Old 02-14-2017, 10:50 AM
GlidingJoe's Avatar
GlidingJoe
GlidingJoe is offline
my guess is the battery is not up to full charge and the computer will not start the bike if voltage is low, when you got to crank battery voltage might be to low.
Old 02-14-2017, 11:54 AM
grande78's Avatar
grande78
grande78 is offline
also try your security pin in case it lost the key fob sync
Old 02-14-2017, 03:33 PM
BrokenAnchor's Avatar
BrokenAnchor
BrokenAnchor is offline
My service guy told me with the new M8s you should have around 14 volts in order to provide sufficient power to crank them over due to all of the draw on power for the new bikes.
Quick Reply: bike will not start
