Mystery Hose on Street Bob
im going over my bike, checking for loose bolts and such for the upcoming summer season, and I noticed a small rubber hose at the front end of the tank. It goes down the front and bends 90 degrees underneath the tank. Doesn't attach to anything. I can't find this thing in the manual, but am I right in thinking it's just for venting the tank? I can see the crossover hose under the tank, but I don't see anything this guy should connect to.
Does it hook up to a valve of some sort or just a hose? Is it on the left side front? Does the bike ever leak gas?
No leaks = continuous venting system (especially if hooked up to a valve which it should be)
Leaks = crossover line for tank sides (doubtful since you aren't mentioning leaks)
