swing arm bag
Old 03-22-2017, 02:44 PM
Freak Show's Avatar
Freak Show
Freak Show is offline
Default swing arm bag
do you prefer a bracket or straps?
Old 03-22-2017, 03:34 PM
Geoff's Avatar
Geoff
Geoff is offline
I use the straps that came with my HD swingarm bag. I applied electrical tape to the frame so the straps don't damage paint.
Old 03-22-2017, 07:57 PM
Freak Show's Avatar
Freak Show
good idea
Old 03-22-2017, 08:08 PM
sbarron's Avatar
sbarron
sbarron is offline
I used friction tape, (like you'd wrap a hockey stick with). Keeps the starps from sliding and is heavier than electrical tape.
Old 03-22-2017, 08:10 PM
matte's Avatar
matte
matte is offline
I have straps on mine. But considering switching to a bracket for easier removal.
Old 03-22-2017, 09:03 PM
pipeyeti's Avatar
pipeyeti
pipeyeti is offline
I used 250lb zip ties the biggest I could find. Used 4 instead of the straps and pulled them super tight.
Old 03-22-2017, 11:12 PM
Rocker B's Avatar
Rocker B
Rocker B is offline
On my Breakout, I used gaffers tape to protect the paint, and 8 large zip ties (2 at each mounting point) to attach a Leather Works swing arm bag, then used the leather straps that came with the bag to cover the top zip ties.....for looks only. I put the buckles inside the bag so you just see the straps, but if you like the looks of the buckles, you could also leave them visible, outside the bag.
Old 03-23-2017, 03:04 AM
EagleRay's Avatar
EagleRay
EagleRay is offline
Yep, taping the swing arm is important to protect the paint from being rubbed off no matter whether you use zip ties or straps. I used 2 layers of 3M electrical tape, too.
My new swing arm bag came with 4 black tie down straps similar to those
http://www.rhinorack.com/en-us/produ...aps-10ft-_rtd3
With those straps you won't be limited to the holes/grid of the the leather straps. They can be tightened as fast as zip ties but are much softer allowing for a smoother fitment around the swing arm struts and less likely to work their way through the protective tape.
So far they do an excellent job.
Sure you can find them much cheaper on eBay or Amazon.
Old 03-23-2017, 06:03 AM
rowan's Avatar
rowan
rowan is offline
I had been running the HD solo/swing arm bag, It came with a clear protective covering
That attached to the swing arm. It has held up well for the past 2 years.
Old 03-23-2017, 07:46 AM
Freak Show's Avatar
Freak Show
i used to have 2 zip ties for each spot, but then the looped ends came apart. so now my choice is to either get a new bag or go with brackets and just drill some hole in my bag to accommodate the brackets
Quick Reply: swing arm bag
