"Group Buy" on New, Cheaper Touring-Stabilizer! PICTURE!!
Group-buy has ended!!!
NOTICE: THIS GROUP-BUY IS OVER!
**There is a thread started for "Reviews" here: https://www.hdforums.com/forum/touring-models/291697-new-touring-stabilizer.html
This Touring Stabilizer is made of laser-cut 1/4" steel, stainless-steel hardware, shouldered washers for the frame cross-member and are powdercoated black. It has vent holes cut in it, and also allows air to flow between it and the pan to release heat, the spacers are TIG welded on the plate for a nice snug fit around the pan taking the stress off of the bolts. Only a couple tools are needed and it will install in about 25 minutes. If clearance is a concern, you would have to almost drag the frame itself on the ground to scrape this thing. It sits nice and tight up where it belongs. It also will come with good instructions w/ photos for installing it. They are $195 powdercoated and $165 raw-steel shipped free in the US off the website www.throttleupindustries.com. Check it out and see what else is coming soon! I look forward to dealing with you.
Aaron
EDIT: I just put up the installation instructions in a .pdf file on the website:
http://www.throttleupindustries.com/...stallation.pdf
Aaron
PayPal is how the business is set up to run. Thanks!
Aaron
Aaron
