Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
CV Carburetor Jet Adjustment
Old 06-30-2005, 11:31 AM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Default CV Carburetor Jet Adjustment
Our most common question about carburetor and Fuel Injection is "How do I know if my jetting is correct? A typical question might go; " I just added a new motorcycle exhaust system to my bike. Do I need to change the jetting? My exhaust color seems to be fine." Or, "I don't have access to a Dyno, how do I tell if my jetting is correct?" Long before Dynamometers became common, we used to do jetting using the "plug chop" method. We will discuss it and some general jetting rules here.
From the factory, your motorcycle came with standardized EPA mandated lean jetting and restrictive intake and exhaust. In some locales, this jetting is so lean it must be changed to prevent damage to the engine. The standard jetting has varied over the models of carburetors and model years.
All of the motorcycle part information below is based on your engine intake system being properly sealed and no other problems exist. An intake leak will throw spark plug readings way off. One of the most common problems is the off idle "pop" and backfire at slow engine speeds. This is usually caused by the idle mixture being excessively lean and is easily corrected by correct jetting and / or the use of a jet kit. The ignition timing needs to be correct and the ignition system must be functioning correctly. A weak or poor spark will drastically alter your plug readings.
We like to do our jetting in two stages. First, we need to get the idle and low speed jetting correct and then we work on the high speed or main jetting.
In our example, we will discuss the Keihin CV used since 1989 on Sportsters and 1990 on Big Twins. The adjustments may differ for S&S "E", HSR Mikuni and others such as the Quick Silver from Edelbrock.
Before you start, have a collection of fresh unused plugs gapped and ready to use. We will need at least three new sets for this test. We use Champion plugs for plug chops. You can get them at local motorcycle parts stores for far less than the OEM plugs. EVO Big Twin use RN12YC. EVO XL and TC88 use the RA8HC.
On the CV, adjust the idle mixture while idling. Closing the idle mixture screw slowly should cause the idle to become rough. Slowly turn the screw out until the engine again idles smoothly. Add approximately 1/8 to ¼ turn more. If closing the screw makes no difference in idle speed or smoothness, you will have to use the next smaller pilot jet. Until the 2000 model year, most Big Twins have a #42 as the stock pilot jet. 2000 models use a #45 stock. In some cases, depending on the bike setup and altitude, a #45 may actually be too large. Drag Specialties provides a #44 pilot jet, which works very well under most conditions. If you have to turn the screw out more than 3 turns, consider increasing jet size to the next larger pilot. A Creative Cycle Products idle mixture needle (CP005) comes in handy here as it allows you to adjust the mixture without tools.
After setting the idle speed and idle mixture correctly, change to a fresh set of plugs. We highly recommend using some anti seize on the threads to prevent galling. After installing the plugs, you want to ride around at part throttle gently accelerating but keeping below ½ throttle. You want to stay on the low speed circuit as much as possible. After about one mile, pull in the clutch and kill the engine. Remove the sparkplugs. Look at the insulator from the tip down as far as you can see. We are not concerned with the grounding tip or the base of the plug. We are looking for an off white, eggshell to very, very light tan. The rear plug should read slightly richer than the front and you want to jet off of the front cylinder readings. The reason for the difference is inherent in the design of the 45° V-Twin and the intake. If you are reading to rich, you may need to lean out the pilot jet or close the screw slightly. If you are reading very white or no color at all you will need to open the idle mixture more or
The following 9 users liked this post by HDF Tech:
$ Short (10-24-2022), blacksnert (05-19-2016), CapAmerica61 (03-19-2020), Colo-WG (04-19-2021), CVX20 (03-28-2024), Fureek (06-09-2019), HOGDAT (02-16-2020), sledhead140 (04-16-2022), vicsponjr (01-13-2023) and 4 others liked this post. (Show less...)
dirtfarmer
01-19-2018 06:47 PM
CETSportster
Ironhead
03-08-2012 09:10 PM
tbell
Exhaust System Topics
02-19-2012 04:11 PM
popstheoldman
Ironhead
03-21-2010 09:44 PM
TXCHOP
22
07-08-2007 07:29 PM
Quick Reply: CV Carburetor Jet Adjustment
