Digital gear/rpm indicator resets
I have a 2011 Heritage that has a digital window that has 2 trip meters, miles to empty and clock, and a selection for gear/rpm. When I have selected the gear/rpm it displays correctly until the engine is turned off. When restarted it displays the digital odometer and I must toggle the switch to display the tach each time the bike is shut down. I have removed my piggyback tuner and cleaned and tighten battery cables, no change.
Anyone have this happen or experience to give me a direction to take on repairing this?
There is 16K miles on it with no other mods or additions.
Thought that might be, but it has always stayed where it was selected until a few weeks ago. I assume there is something amiss.
That's my logic also. I am hoping someone else had this happen and can give me a direction to take.
re-boot
My 2012 slim does the same thing when the battery is less that fully charged. For some reason my electric compression releases have stopped working and if I let the bike sit for more than a few weeks, as I have since I broke my leg, when I go to start it, it will all but stall the starter out. Whenever it does this my digital display defaults to odometer. It's probably getting time for a new, better battery.
I also noticed a second symptom: When digital tach resets to odometer after restart, when I toggle back thru display, the miles to emty read out reads LO RNG. I do have a Gremlin with something. I may try the reboot idea and then consider a battery.
May be additional ideas out there also?
