A First try Finding an independent Shop
I have a 2013 Breakout and kind of like working on the bike . I do my own Service and will do a cam this winter . With that said I hate wiring and will not work on it no way . So today I call around looking for a quote from a shop I don't know any so it is all by feel . The first two do not answer the phone the last guy does answer but what an idiot . I tell him upfront I would like an idea of cost to do my handlebars as I am going to apes .
I also tell him I have a 2013 Breakout and thinking 14 inch apes . This guy mumbled to himself doing the parts lookup and give me a price just short of $200 bucks . So I ask this is for the Bars Wiring and clutch -Brake cables and labor and he said no just the bars . So I say again I am looking for a price of the handlebars installed done out the door . After this fool ask me three times what bike do you have ( in less then 90 seconds) I hang up .
Beginning to think I need to just do it myself
i can sympathize with hating to do your own wiring. I cut and lengthened my own cables when I put on 14" apes. so take the amount of wires in there and times it by 2, that's how many solders i had to do. It sucked. Oh, and then I realized I cut the extensions about 4" too short..so I had to do it all over again!
Unless you're going to try to hide the brake and clutch cables, those are easy-peasy too (except having to remove the exhaust if needed and opening up the clutch housing cover on the side)
But it's really not that hard, and once you get a good rhythm going it goes fairly quick. Burly Brand and several others make cable kits and extensions that are pretty plug-and-play, and would cost about the same as an indy. If you can do your own cams (another easier-than-everyone-says job, in my opinion) you can do your own bars.
KEYBEAR, your Breakout is one of the easiest bikes to do a bar swap on. You do not have to remove the connectors from the wiring. With the new can bus bikes, the connectors are small enough that they will pull right through the holes in the bars. You literally go under the tank, unplug 3 connectors, pull them out of the bars, feed them into the new bars, and plug them back in.
For 14" apes you will need extensions. The extensions come as a piggyback with a connector already on each end. It is all literally plug and play.
https://www.hdforums.com/forum/softa...-breakout.html
After MANY years of looking, trial and error I have found an INDY I would leave my Grandson with!!! This guy is the BEST! He is a straight shooter, REALLY knows his stuff and people come from all around to have him work on their bikes.
I met a husband and wife team on here that lives about 60 miles away, they bring their bike all the way down just for this guy to work on. There's not allot worse than trying to find competent craftsman these days. He did my bars, all internals and it came out SO sweet!!!
