Winter storage????
11-25-2014, 06:46 AM
Lucas, it also helps with the ethenol. Bike, lawnmowers, tractor, weedeaters, blowers, boat, on an on an on.
11-25-2014, 08:16 AM
Seafoam has always done the trick for me.
11-25-2014, 11:45 AM
11-25-2014, 07:19 PM
Quote:
Originally Posted by
jgos929
Seafoam
..another vote for SeaFoam here...
11-27-2014, 10:45 AM
Stabil for storage.
Chevron techron for cleaning when I forgot the Stabil
11-27-2014, 07:29 PM
jgos929
Seafoam
I was going to try that, but couldn't figure how to strain the sea creatures out first.
11-27-2014, 07:36 PM
FurryOne
I see you're not too far from a limitless supply, also...
11-28-2014, 12:25 PM
Be sure to
run the bike after you put in the Stabil so the Stabil treated gas is in the carb or EFI.
11-29-2014, 06:23 AM
If you use Stabil dont use the Red stuff if the gas in your area contains ethanol. Only the Marine Stabil is designed for use with ethanol and where I live there is almost no real gas to be found.
11-29-2014, 10:29 AM
This is absolutely false. The normal, red stabil works perfectly with ethanol blends. It even says so on the front of the bottle:
http://amzn.com/B000B68V6I
martin10
