Front signal mounts
Front signal mounts
Recently picked up a '07 Fatboy; beautiful, well done bike. Previous owner installed chrome grips, switch & switch housing, and braided cables. Looks good other than the stock mounts for the front turn signals; appears Harley put little thought into these. I'm not interested in relocating the signals, just replacing the mounts with something more substantial. I've come across the following options from Harley; was wondering if anyone had experience with either.
Part Number 68266-03
http://www.harley-davidson.com/store...gnal-mount-kit
Part Number 68185-00
http://www.harley-davidson.com/store...l-assembly-kit
Thanks for any input.
If you did decide to relocate them you could do it for a lot less than either of those H-D kits.
On another bike I had last year, I just used two H-D manifold studs (p/n 16715-83) and moved them to the lower shroud bolts.
They were 5/16" studs about 2" long with different threads on each end - one coarse, one fine. I think I spent about $4.
The coarse end went into the fork, and the finer thread fit the turn signal housing.
Nothing to it. Hardest part was unplugging and re-routing your cables.
something like this:
I went with the second kit, it's a direct replacement for the OEM mounts and install is a piece of cake. just follow the directions.
The first kit will relocate your signals, believe it or not. It will move them up closer to your grips/levers, and out about an inch or so. I think somewhere in the description indicates this, but you can see how the swivel is relocated to the outside of the mount and up near the levers. I chose not to use that one due to my long fingers and I didn't want interference with grabbing the levers.
If you're not relocating the sigs now or right away...go for it, it really cleans up the area nicely. Don't over tighten, I must have had a bad batch because the chrome flaked off and I had to return for a new set. However, I did notice that the lock washer location differs between the pic on the website and the diagram in the instructions. I went with how it is in the instructions, and maybe that's why the chrome flaked off.
Did you have to cut the wires
I realize this is an old thread, but it has a new question. To begin with, the exhaust stud will not work on a newer FL Softail. The threads in your signal housing and in the fork are both 5/16 fine pitch (24 tpi). You will need to find 5/16 24tpi threaded rod and cut it to the desired length, when I did mine I drilled holes in the fork tin and used a rubber grommet to run the wires through. Then when I decided I didn't like the signals there...I was left with the hole in the tins and then the coating started to peel.
Take the easy way out. Buy a set of LED lights with 5/16 24tpi mounting studs and internal wires. You get the benefit of a brighter light and easy install. Looking back, this is what I would do now if moving the signals to the forks. Here is a link to some great signals.
http://www.hightechspeed.com/products/XArc/index.asp
One more question thank you
Will not work
Clever idea, but on my Softail, the fine thread goes into the lower fork tree and the coarse thread fits the turn signal. Standard engineering practice is fine threads in hardened steel (exhaust flange nuts or fork trees) and coarse threads in aluminum (cylinder heads) or pot metal (turn signals).
