S&S 98" big bore kit
Hey guys,
About to order a big bore kit for my 2004 FXSTI. It currently has Freedom Performance Exhaust Sharp Curve Radius Exhaust, a Big Sucker Air Filter, and a Power Commander. Has anyone used this before? I think it just came out in 2014. I'm looking to use their gear driven 510 cams as well (i'm going to have my shop check out the crankshaft run out before I order those). Just looking for some feedback. S&S claims that that with the 98" kit and the 510 cams they get 100 hp and 108 ft/lbs of torque.
Should I look at upgrading from the power commander to something newer?
http://www.sscycle.com/go-fast-showc...-big-bore-kits
Thanks
Thanks
Ok I'm set on the 98" kit from SS.
Now just trying to decide the cams. I was set to go with the 510 from S&S, but have been reading a lot about Woods and Andrews cams.
The type of riding I do is just general cruising on the highway and back roads, don't ride much in cities. Never ride 2 up.
Thanks in advance.
Thanks in advance.
Guessing that different size cams, how ever minute, will change the overall volume in the cylinder head space.
Is this the reason for your question?
May I suggest......Talk to a well trained and informed tuner guy, you know, a dyno guy? Tell him what you are looking at doing and he will steer you in the right direction. I strongly suggest getting head work done while its off. That may change the cam you want to use and your tuner. JMHO, but to go that far and doing no head work is a sin. Flowed, ported and polished and possibly bigger valves too. I cant stress that enough.
EDIT: Mine was born a lil 88 ci too. I have the 95" kit and im pushing 100/100 on mine and that's with these cholos on it to rather than my Python 2 in 1. Not to shabby!!!
