Need Sprocket Change
OK, this bike needs a ratio change something fierce!! We all know these bikes are geared fall from the factory anyways to meet CAFE, EPA, and noise standards. But with the new cams now, it's worse. Since the cams have moved the rpm range where the bike likes to run up a bit, it's even worse. I'm constantly running a gear lower that I was before the cams just to keep her happy. And pulling away from a stop seems like forever to get the clutch all the way out.
But anyway...so what are my options? Doesn't seem like I see a lot of talk about throwing on a larger rear sprocket. Are there not many options? Smaller front sprocket...which seems like more work to install. Thanks for any tips guys.
do know if this is info you're looking for
I did SE-255 cams last summer and clutch slipped like a bitch when jumping on it. Then I installed SE Clutch Spring which cleared up 80 - 90% slippage when banging on it. I just put the Andrews 30T Trans pulley (stock 32)on with a 70T Harley Pulley(stock 66T) and Hayden M-6 (?) Chain Tensioner on. Good news I was apply to reuse stock belt! Ball parking ratio change for the Six Speed was ~ 2.790 to 3.10. Now when I bang on it, it ***** and gits. I only have 25 miles on this combo so I really can't comment on around town overall drivability yet, but I have noticed 2 things - 1) I'll need a few more miles on it to find right gear for 35 - 40 MPH around driving to avoid chugging and 2) when I stomp on it - she goes!<p> I ride it like I stole it more often than not. I'm a gear head, what can I say!
I would think a larger rear sprocket woul do the trick and be an easier and cheaper job. Have done that on every bike I've ever owned...plus a few vehicles. Nothing beats a gear change for overall driveability. Just to clarify, my clutch doesn't slip at all. It just take a lot more feathering to get underway and creep in 1st gear than before the cam change.
a word of caution or two
my rear is a 200/55r/17 so rear sprocket is 20mm to accommodate wider tire. also somewhere in my research I found a site that has a belt chart for sprocket combos for OEM. I went from a total of 98 (32+66) to 100 (30+70) and was able to use my belt, though I don't know for your specific case. Also the sprocket mounting boss was a different thickness, so I had to use DS Spacer. (I owe thanks to the threads here for that info! thanks guys!)
