I know I'm late to the party, but for anyone else looking for this oil line tool you can by Air Conditioning line removal tools at the local auto parts store. Very cheap... I recently removed the oil tank on my FatBoy and I was able to undo the lines with my fingers, FYI.
Ordered! Mind if I ask you for distructions? Maybe through a pm ir here if no ine minds? Thanks a bunch man
Splatt, My post #9 this thread has all the instructions you need on the link.
After drilling the hole to connect the 2 chambers of the puck, I plugged mine with JB weld rather than tap threads for the small plug (on the side) that will never be removed.
Steve
Correct, the JB weld is the simplest, and I guarantee there's insufficient clearance for the small plug, .... I even had to take the Dremel to the JB Weld for clearance with the engine casing.
