Need Exhaust Advice
Need Exhaust Advice
Wanting to change the exhaust on my 2016 Heritage Softail Classic, and it is down to the Vance and Hines Big Radius 2 into 2, or the Basani Radial Sweepers. I have never had a Basani and was wondering if anyone had any input on either of these pipes. Thanks in advance!
Bassani > V&H. Fit, finish, performance, chrome, ceramic coating and customer service are superior. I deal with this stuff every day at my shop and personally use Bassani exhaust on my bagger. I am not a huge fan of that style exhaust on a Heritage, but it is your bike and if that is what you like, go with Bassani.
I use Bassani Power Curve Duals head pipes on my bagger. My HD Tech uses their Road Rage 2-1 system on his bagger. On a Heritage I prefer a more classic look and would run their fishtails. If you don't like that look I would run their Fire Flight pipes with the aggressive slash cuts. But like I said, your bike, your choice. I will caution that the Radial Sweepers you like are a bit of a challenge to tune due to the rear pipe big so much shorter than the front pipe. That being said, if you had both sets of pipes (Bassani and V&H) in front of you, you would find the quality of the Bassani pipes to be much better. Thicker heavier heat shields with better chrome and better welds. I hope this helps in your decision!
