Best power producing pipes out of the 3
Vance and hines 2 into 1
bassini 2 into 1
d&d 2 into 1
i heard the later 2 were dynod with better results than the vance and hines?
I have a fp3 tuner as well...and se intake
i have a 2008 rocker c, motor just broken in....but i have plans to move onto different motor, another thread, for the 96 motor i have , please respond with results or dynod experience, not personal fav's or what you have thanks
bassini 2 into 1
d&d 2 into 1
TOMMYBLAZIN (10-09-2016)
If you are talking about a V&H big radius 2 into 1, it don't make a good torque curve, the V&H 2 into 1 Pro Pipe is a good exhaust and proven performer.
The D&D Fatcats makes a good torque curve, the low cats and Bob cats usually have a pretty good torque dip between 2000 and 2700 rpm but do ok in higher rpms. The torque dip can be felt, I switched from a low cat to a Rush Wrath on the same engine and the butt dyno could feel the difference at cruising speeds and WOT. The dyno sheet showed the difference too.
No experience with the Bassani 2 into 1.
Basically, the longer pipes make more power (torque) and that's what you feel when you twist the throttle, especially on a stage 1 or 2 bike.
yea, to say you cant feel the difference, I have a 2 into 2, that's just for looks, the vance and hines, going from what I have to a 2 into 1, I WILL notice, I just got bike back yesterday with the 70/30 mod, felt that? lol, thanks for the input, I didn't know vance and hines made 2 different 2 into 1 pipes?
[QUOTE=FLS103;15579910]If you are talking about a V&H big radius 2 into 1, it don't make a good torque curve, the V&H 2 into 1 Pro Pipe is a good exhaust and proven performer.
Basically, the longer pipes make more power (torque) and that's what you feel when you twist the throttle, especially on a stage 1 or 2 bike.[/QUOTE
Have you tried or anyone know of the Thunder Torque Inserts from dk customs, dyno sheet numbers look insane?
