Thinking of adding jug cooling fans
RJ09softail (03-13-2017)
By your name I assume that you are on a Softail. If this is the case there is an awful lot of heat associated with that oil tank,which our product will partially cover but still allow you to check your oil ..
Capt. Itch's product is certainly worth the money and should probably be the first "fix" to a heat problem if the heat problem is comfort related.
I'm adding the Love Jugs Mighty Mite to my Heritage due to I'm also adding a set of Leather Pros leather lowers so I'm anticipating getting less airflow to the Jugs which likely will result in higher jug temp.
Plus I kinda like the idea of having some "Love Jugs" between my legs when I ride
RJ09softail (03-14-2017)
