Cleaning stuff off chrome pipes
Old 08-22-2007, 10:57 PM
AlohaFlyer's Avatar
AlohaFlyer
AlohaFlyer is offline
2nd Gear
Default RE: Cleaning stuff off chrome pipes
That is a good point... cold works ok too... plus you can hang a little towel behind your pipes to catch the over spray.... he's right... be really careful around the painted surfaces... also I usually watch the fumes too... use your t-shirt or a mask...
Old 08-22-2007, 10:59 PM
crock921's Avatar
crock921
crock921 is offline
will it screw up the black finish on the engine block? (night train)
Old 08-22-2007, 11:00 PM
AlohaFlyer's Avatar
AlohaFlyer
2nd Gear
no it won't if you do not allow it to sit very long...
I have over sprayed many times and never had a problem... I never let it sit on anything more than 30 seconds at the most...
Old 08-23-2007, 02:45 AM
grzly's Avatar
grzly
grzly is offline
great timing for this thread - my daughter just left half her shoe on my pipe ! Never seen so much mess.
grzly
Old 08-23-2007, 06:33 AM
martyandpeg's Avatar
martyandpeg
martyandpeg is offline
Thanks all. I will have to try the oven cleaning method.
Old 08-23-2007, 09:08 AM
crock921's Avatar
crock921
crock921 is offline
i think some sort of drop cloth behind the pipes sounds like a necessary and worth-while precaution
Old 08-23-2007, 09:12 AM
nite trainer's Avatar
nite trainer
nite trainer is offline
6th Gear
I have used oven cleaner and it works ok but I picked up this stuff called ROAD RUB it looks like a travel deoderant stick but have prove easier and much less chance for error I picked mine up at the dealership but you may be able to find it online.
Old 08-23-2007, 09:14 AM
crock921's Avatar
crock921
crock921 is offline
so you put this road rub on and then polish it off?
Old 08-23-2007, 03:18 PM
nite trainer
6th Gear
the directions state: This product utilizes a dry cleaning method. Allow chrome to cool down. Remove Cap. Press stick firmly against chrome and rub vigorously. Wash and rinse chrome.
I almost alway polish the easy to reach chrome ie. my pipes, air cleaner, oil tank etc. so i've never paid attention to whether it needs to be polished or if its ok with just a wash and rinse off with that let me say i don't spend 4 hours polishing either it's a quick once over.
Old 08-23-2007, 04:34 PM
harleydad's Avatar
harleydad
harleydad is offline
Sea foam carb cleaner, dab some on let it set 2 or 3 min., wipe off.
safe, no abrasives, easy to control where it gets dabbed on.
try it, you won't need anything else.
Quick Reply: Cleaning stuff off chrome pipes
