Thundermax/Check Engine Light????
I've had the Thundermax w/AutoTune on my '08 Softail Custom for about 1-1/2 months. On three occurances, my check engine light has come on. Two of the times were while I was at the Fall Rally in Myrtle Beach, and the other time was just this past weekend during a Toys For Tots ride. The first time it happened, I was pulling into the parking lot at the Harley dealer in Myrtle. I went right inside and talked to the service guys. They checked the code and told me it was just a communication problem and that there was no real issue. It did it again later in the day as I was pulling into another parking lot. This last time, I was pulling in the parking lot at our local dealer after the Toys For Tots ride. All three times I was in stop-and-go traffic. After the bike is parked for a little while and it cools down, the check engine light goes off. So my guess is that the bike is overheating. I never had that problem while the bike had the stock ecm. But maybe I was never in stop-and-go traffic while the bike was stock either. I can't remember. Is anyone else having similar issues with the Thundermax or even with the stock ecm? I'm planning on sending Zippers an email asking them what the problem is.
RE: Thundermax/Check Engine Light????
ORIGINAL: Dinger
I see you have an air cleaner. Are you running a tuner? SERT, V&H Fuel Pak or Dynojet Power Commander?
Have you had bike dyno'd and your tuner remapped for your mods?
ORIGINAL: bdavis385
READ THE MANUAL. It tells you quite clearly that when the check engine light comes on your head temperature has reached a point of danger. It's default setting is usually in the 320 degree range.
I just called Thundermax tech support. The guy was very helpful. He told me that was a feature built into the Thundermax to let the rider know the bike is overheating (temp reaching 350*). He said a stock ecm will not do that. He said a stock ecm will "let you just sit there and melt" without telling you. I figured the problem was heat related since it has only done it in stop-and-go situations (bike week twice and toy run once). Luckily, the light has only come on as I'm pulling into a parking lot and I'm able to shut it down quickly.
WOW!! Is that true???Does installing a Thundermax void the warrenty? I've got an extended 5 yr warrenty w/ 4 years left on it. The last thing I want to do is mess with the extra coverage you pay dearly for. So...if this is true what are you guys recommending. I'm wanting to do a stage one upgrade and was looking HARD at the T'Max. Sorry to hear about your overheating problems, I thought one of the reasons for doing the stage one was to help with the cooling. Why didn't that happen in your case? I have a temp gauge in my oil dip stick and mine usually runs around 210-230, every now and then it will hit 250... 300 plus seems awful hot. I wish you the best and keep us posted. I was at bike week also...that stop and go can really get'em hot. By the way...Nice looking bike you have there.
