What am I gona need to change the fluid for the 3 holes?
RE: What am I gona need to change the fluid for the 3 holes?
In the winter I run the syn3 in the tranny, but in the summer I switch to the bel-ray. It gets down well below freezing and the syn3 works good in the cold. When it gets up above 100 degrees outside, I have problems with the syn3. Don
Oil filter K&N are the easiest to off. 4 quarts of Mobil 1 v twin 20w 50 for the crank and you'll have a little left. 1 quart of redline heavy gear oil 75 140 for the tranny, and whatever you wanna put in the primary. I use wahtever oil I ahve around or leftover from the others. I am not sure of the amounts for your year as my bike is a bit older. But that's what I use...
ORIGINAL: TexFordD
Take one of the small size Folgers plastic coffee cans and cut about half of it away except for about an inch from the bottom.
Put your filter strap on and then slide this under it all the way to the end.
You and I have the same bike.
I did it at the 5k service. Did that myself.
The dealer said I needed 10 qts of Syn3. I ended up with one left unopened.
Works great. No clunk or weird noises. Shifts fine. Runs about 200 degrees on a 70 degree day after 2 hours of riding.
