Springer Front End Wobble is getting worse
25,000 mile 98 Heritage Springer front endprobably started to vibrate when an HD dealer replaced all front end bearings 10,000 miles ago. The vibration has now turned into a full blown serious wobble between 25 and 50 miles an hour. Loose hands on handlebars feels instant vibration. No hands quickly develops into dangerous wobble. Tires changed 5,000 miles ago and balanced twice. Spoke wheel never adjusted since factory. I think it may be springer steering head bearings, but do not trust dealers to do the job right (they charged me $600+ to do it wrong maybe). Everything else about the bike is great. Just replaced primary adjuster with HB 125 hydraulic, and it seems to work great. Shifting is getting a little too much clunk.
What do you think is causing this unnerving wobble?
What can be adjusted to reduce the HD shifting clunk?
It is getting bike season, and I need to correct these problems soon.
Help! Thanks,
vb
Help! Thanks,
vb
RE: Springer Front End Wobble is getting worse
yes as he said above steering neck bearing adjustment ..this is critical , also adjust your rockers...my buddy had approx 12000 miles and same thing on his 03 FLSTS..we changed head bearing and did the fall away adjustment as per manual but the wobble came back..we just did his rocker bearing adjustment this spring(they were so out they were sloppy) and his wobble is gone..I did mine as well (03 FLSTS) but werent that bad and had no symtoms...he also installed new tires with dyna-beads balancing agent but I dont feel that was the cure..it was the rocker adjustment in my opinion...
Thanks Gentlemen,
I will adjust both the steering head and the rockers. They must be a little loosie goosie. Italked to a great mechanic at a non-HD shop this morning, and he told me to give the Hex bearing retainer a quarter turn tighter. I should then see what effect if any it has on the wobble and maybe take it another quarter turn if it seems to get better. I have to make a tool out of another hex bearing nut and some dowels, but since I have a Springer he said it is a good idea to have the tool anyway. Springers are beautiful, but they require a little more TLC. I will also check the spokes again. The last time I checked the spokes they all sounded about the same tone, but it never hurts to check again.
I appreciate your help.
vb
vb
1 Post
I own an '07 Springer Classic.
I ride the F#*K out of it and at like 3,000 miles I experienced the same thing.
I thought the damn thing was gonna fall apart. Thought about trailering it to the stealership for a second, and said the heck w/ it, I'll ride it...slow!
Got it there, and they said that the lower rockers (think thats what they called it) were extremely loose, and about to back out on themselves.
One mechanic started to ask how I ride it, when another interjected, and said look at the pipes, frame, floorboards, rear tire, etc.
Enough said...Springers are higher maintance, and not built to hot-rod, So...keep up on maintance, and take her easy (lol).
