Radio Shack Alarm on Rocker
Hey has anybody done the 6 dollar siren on the Rocker?
I tried to find the plug on the rocker. But the plastic guard on most softails, that comes off with two bolts off the bottom, is quite different on the rocker. We have a plastic guard as well but it is held on by two allen bolts that seem impossible to remove without taking off the fender. I'm going to keep looking but I thought maybe some of you guys who have done some stuff might have seen the plug
RE: Radio Shack Alarm on Rocker
i have been wondering the same for mine, i will look tommorrow and see what i can find. im almost certain the alarm is under the seat directly in front of the battery a little black box with a plug on the exhaust side goes into it.
if you have the newest service manual it may tell you where its at, i had to order my manual and it has not came in yet. also not sure where we will put the siren with the little room on these bikes.
ill let you know if i find anything
Just installed the Radio Shack alarm on my Rocker C. I removed the fender first (4 bolts) and made it easy. Once the fender is off remove the two screws on the plastic cover. Once inside, everything looks the same as on previous posts. Connect and replace cover and fender. Easy as can be.
