Deluxe back Rest using Springer Parts
Hey all
I have seen a couple of postings on this already.
I am trying to put a driver back rest on my 2008 Deluxe using some older springer parts.
I know the partsI need:
52087-98 - Grab rail for driver seat
52827-97 - tall back rest pad for grab rail.
I can find lots of places that havethe grab rail, but no one seems to still have the tall back rest pad in stock. It has been discontinued for a year or so. I am in Canada, but I have tried all the places I can think of in the United States as well.
Anybody got anyideas on where/how I might find one.
thanks
Loving my new bike and still Smilin in Canada!
thanks
RE: Deluxe back Rest using Springer Parts
The tall backrest is tough to find. I checked with dealers in several states without luck. On ebay, they were going for $200+ and I just wouldn't spend that much for a pad that may or may not function well as a backrest. Some folks have indicated that it is too far back to be really effective. In any event, it covers up the springer grab rail which is what I wanted to be visible. There is a guy on ebay that makes a bracket and backrest pad that he indicates will work with the grab rail and sells them for about $100. I haven't looked into it.
Moving the backrest forward is EASY...simply add a chrome spacer between the fender mount and the center down rail. You will need a longer screw, but a 3/4 inch spacer moved the wife's rest forward almost 2 inches.. I used stacked washers to find out how long I needed the spacer to be, then bought the spacer. This way, you get what you need the first time out.
I have added a photo, with the spacer circled in red for clarity.
[IMG]local://upfiles/9327/56E5391C5BCB4C048BCA9631E541B95F.jpg[/IMG]
Thanks all.
I still can't find the pad, but I will keep looking.
Appreciate the comments on moving the rail forward.
I am assuming that it mounts the same way as the stock grab rail.
A friend of mine bought a back rest from firehouse , works O.K., but not nearly as good looking as the springer set up.
Now if only the stockseat was a little more comfortable!!
Gerry
Gerry
ORIGINAL: Trailfndr
Thanks
ORIGINAL: smylieg
Thanks all.
Gerry
Thanks all.
Gerry
Here Is A pic Of It
