Deluxe - Removing "salad bowl" from front wheel, how to?
06-18-2008, 12:02 PM
Madame Moderator
Please advise. \\; Did search first but no luck. \\; Thx!
06-18-2008, 12:09 PM
RE: Deluxe - Removing "\\;salad bowl"\\; from front wheel, how to?
Remove the front wheel and i am sure its just a couple bolts/nuts holding it on there
06-18-2008, 12:11 PM
RE: Deluxe - Removing "salad bowl" from front wheel, how to?
The front tire is obviously the easiest to remove...and the rest was history.
06-18-2008, 12:15 PM
REMOVE TIRE, REMOVE HUB CAP, INSERT SPACER, REPLACE TIRE, RIDE
Madame Moderator
Yeah, that makes sense and sounds simple enough, but just never hurts to ask first. \\; Much obliged.
06-18-2008, 12:18 PM
FORGOT, INSURE WHEEL HAS MIN. RUNOUT.
06-18-2008, 12:23 PM
You would have to replace it with a spacer on that side. \\; When you chrome your front end you will have the option to replace the "bowl" with chrome spacers on either side of the wheel. \\; Hey, you want to chrome the front end anyway.......
06-18-2008, 12:29 PM
Madame Moderator
Thanks spikehyre, and yes, yes I do. \\; It's only money right?
06-18-2008, 06:37 PM
RE: Deluxe - Removing "\\\\\\;salad bowl"\\\\\\; from front wheel, how to?
Money and about four hours. You can do it GG.
06-18-2008, 07:04 PM
RE: Deluxe - Removing "\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\;salad bowl"\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\; from front wheel, how to?
If I recall correctly, the "Salad Bowl" is held on to the spacer with a spring clip. Pretty easy job to remove the front wheel and the bowl.
