04 Fatboy - Frustrating Electrical Problem
Hey Gang,
Need your collective intelligence on this one...
04 FatBoy has intermittent electrical problem. \\; The problem started suddenly on my return from Mertyle Beach about a month ago...stopped at a light...let go the throttle to idle, and it shut down. \\; \\;The code "bus er" was showing in the odometer window. \\; \\;When it first started, I could increase throttle RPM and the code would dissappear from the odometer window, avoiding shutdown...and the bike ran \\;normal at speed/rpm. \\; But sometimes now, \\;I can't even warm up the bike. \\; At other times it rides without a problem. \\; Nice, sunny day yesterday and couldn't go for a ride...it would start and run for about 15 seconds...then the code would appear, and the bike would shut down. \\; Last weekend....40 mile ride before a shut down...it restarted and got me home luckily.
I think it may be related to the charging system of the bike (stator, regulator, etc) because the battery charge level has been \\;lower than usual (usually at 80% or better) since the problem started. \\; Now it charges about 30-60 minutes to reach the 80% level...full charge in \\;about 2.5 hours. \\; Frequently, I get the code when trying to start the bike...a battery charge seems to help at times but the problem persists and is unpredictable.
Had the local dealer look at it...they couldn't find anything although they did witness the intermittent problem with the code and the shut down...they kept it in the shop for a few days...they \\;cleared codes they said were related to the front/right turn signal problem I was having just before I started getting the code problem. \\; The signal problem was a bad bulb and was fixed. \\; The shop could not find \\;the cause of the code/shut down \\;problem. \\; \\;The shop said it could be a bad \\;turn signal/security module (expensive)
Can't trust the bike for anything but short local rides. \\; Any suggestions before \\;I buy a new turn signal/security module??
Thanks all...
AlbertG
Thanks all...
AlbertG
RE: 04 Fatboy - Frustrating Electrical Problem
First I would disconnect the battery, I assume you have a harness installed for the battery tender/charger. \\;If you do remove the harness. \\;Clean all of \\;terminal connectors and hook it back up without the harness. \\;The \\;second thing I would do is, check any modes I had done to the bike. \\;Third disconnect the front signal plug, under the tank, and see if this isolates the problem. I would also try the same thing with the rear, at separate times. I would check all of the connectors under the tank for a problem.
Thanks for the advice TLB.
I was dreading the thought of removing the tank again...did so when installing new handlebars with internal wiring.
Have there been problems associated with the battery charger harness? \\; I did check all connections at the battery and alternator when the problem first occurred.
I have spoken with 2 dealer shop mechanics about the problem so far. \\; Both feel the problem is probably the turn signal/security module and recommend replacement. \\; I would do it myself but they say it requires "reprogramming" at the dealer...I assume this has to do with the \\;factory security system \\;function. \\; \\;
So it's going back to the dealer tonight for a fix unless I hear something in the interim...
Thanks again...
Regards
Thanks again...
Regards
