Trying to get this done. Site doesnt want to let me.
05 Fatty HD rear brake light module installed.
Right front stays on solid. Intermittent problem. \\;Everything else seems to work normally.
Cycle the ignition switch and it appears to correct.
Left works normally.
Bulbs appear good.
Any thoughts?
MikeM
Try removing the module and see if it fixes it. \\; My brake light was malfunctioning and I took out the braek light module and the problem was fixed.  \\;
Try removing the module and see if it fixes it. \\;\\\\\\; My brake light was malfunctioning and I took out the braek light module and the problem was fixed.  \\;\\\\\\;
I did the same thing as described above, fixed the problem on my 04 Fatty!
