Rocker rear axle removal
guys,
what size allen does the rear axle on the rocker require? i was at the dealer yesterday and they were all a bunch of idiots. no tool available and the service guys did not know what they used to remove it. they had 4 rockers on the showroom floor, so they have obviously wrenched on the rear axle during set up.
please let me know. i need to move my wheel slightly
thanks
thanks
RE: Rocker rear axle removal
ORIGINAL: Citoriplus
Not sure what size it is, but don't blame the dealer guys. They may be dumb, but odds are they haven't needed to touch one yet. They come setup from the factory with the wheels on them already.
the wheels come from the factory mounted and set up? the belt tension is accurate? i doubt all the rockers they had on the floor were set up perfectly and did not need any belt adjustment. i'm sure they have wrenched on the rear wheels.
i need to adjust the belt slightly. it is too tight after installing the lowering kit.
installing axle covers...
I got the kit for the covers and it clearly says to use the manual when installing the covers. You have to remove the axle for sure. I am considering making a jig for the bike to sit in to ensure everything lines back up properly. I'll let you know how it comes out. I got the bike jack recently to make things easier...
BREAK:
kylant, I would check the book before making any adjustments to the tensioner. The bike has an auto tensioner on it that doesn't require any adjustments. I don't know if the lowering kit specifies it but I would check with the stealer..
BREAK:
the axle allen size is indeed 3/4". it was a pain in the a$$ to find the right tools
