Floorboards Falling off my Deluxe
My left floorboard keeps coming loose on my 07 Deluxe. I've re-attached it a few times but after a week or 2, it loosens up again. Seems the board is attached to the metal plate below it by 5 rubber nipples that extend thru 5 holes in the plate. I just talked to one of the techies at my Harley dealer and he told me this is a common problem with Deluxes. The rubber nipples are too soft and they allow too much play. So after a while they work themselves thru the holes. 2 days ago I had to grab my left board before it came all the way off and became road trash. The techie agreed this is a design flaw with Deluxe floorboards and the 09s use the same design. Anyone else see this problem and if so, any recommendations on how to fix it (short of buying new boards)? I'm thinking of some super glue under the nipples. You'd think after a few complaints HD would have redesigned them by now.
Just thinkin' out loud here.......... where the nipples (mmmmm... nipples) come through the plate, would it be possible to put a good sized washer with a smaller hole than the plate.......... and pull the nipples through the plate and the washers???
My mind's picture of this is lookin' pretty good! Let us know.
My wife's nipples came out too. The ones on her Deluxe. She layed it down in the garage one day and the floorboard came off.
I put it back on but since then it keeps popping off. I was thinking maybe I hadn't pulled the nipples down far enough or had missed one but now your question has me wondering if maybe there's a design flaw.
If they come off again I'll give crawdadaz's idea a try. Sounds like a good place to start.
I've had the same problem with my left side floorboard. It has only happened once. My boss noticed it hanging off one night when I pulled up at work. He rides a Goldwing so he is always ribbing me about HD. Makes it hard to argue when your floorboard is hanging off. I like the washer idea mentioned by CrawdadAZ and might give that a go. I'll post up on what I come up with.
Romey
Romey
