Raked cup questions......
Will raked cups increase the distance between your triple trees? I would like just a bit more rake, but with the inverted forks, the fork sliders are flared and flared only where the cinch bolts are, so the distance between the trees can not be changed. I know the angle of the sliders stays the same in relation to the trees, but I'm wondering if the thickness of the cups would spread the trees any.
A. For the past 20 years I have worked on both automobiles and motorcycles for a living(I am a technician)
B. Raked triple trees are not the best way to go normally due to the fact that they reduce trail. Reducing trail basically will make your bike more unstable at speeds and tank slap is more likely to occure. The larger the triple tree rake, the more trail is reduced.
C. Raked cups, dont reduce trail and technically is the better thing to do, but your only going to get a few degrees out of it. At the same time your going to have to make sure your handlebars and risers dont interfere with your gas tank, you also have to worry about the stem of the triple trees themselves as sometimes they may not be quite long enough, and the forks themselves if using stock will end up lowering the bike a bit. The rear will need to be compensated for to keep ride height level to maintain proper handling characteristics, but understand your also reducing lean angle of the bike now as well.
Best thing to do is pony the money up, have the frame taken to a competent shop that is proficient in cutting and raking the frame out through the neck. It costs the most, requires a good portion of your bike being dissasembled, but at the same time will get you the best results.
Received 1,211 Likes
Just tossing in this - raked trees are a good thing if you're using them to decrease the trail on a raked frame bike.
That said, cut the frame! It's just a bike, and boiled down to the essence, if you're worried about the value, you're worrying about the wrong thing! Be worried about not riding the bike you have pictured in your mind!
