Offset or moving brake pedal out?
My wife just purchased a 04 Fat boy, and she is 5' 2". She has trouble with her calve hitting the air filter which reduces the amount of foot that contacts the brake pedal which is an aftermarket large brake pedal.
My question does any one manufacture a brake pedal that is offset setting it further out to the side, or has any one modified the brake pedal to go out wider?
Thanks.
Thanks.
I see on the HD website they have a bunch of large pedals. Have already checked them out? There are two pages. Here's a link.
http://www.harley-davidson.com/brows...bmLocale=en_US
If there isn't anything there that will do, perhaps an aftermarket parts shop can find another pedal that WILL work or I'm certain a custom shop can fab up what you need.
Good luck.
Good luck.
1) replaced the stock pedal with a wider one (she's already done that part)
2) Adjusted the pedal closer to me
... then, there's actually a 3rd component - you just have to kind of get used to it.
The pedals from HD other then some being wider, which she has, aren't wide enough. Surely there is some company that makes one with an outward bend into it. When it comes to my wife and her bikes I want to do everything I can to keep her happy.
Thanks for your replies, and hope some one has a great solution for me.
Toy... I haven't found one anywhere that will physically bring the pedal farther out from the bike like I want (and obviously, your wife does too). I was thinking of going to a machine shop and having one made.
*Maybe*, you can just bend the pedal she has (or get a shop to do it). I don't know if you need to heat it. I tried bending mine, but my vise is mounted to a workbench that isn't very heavy or attached to the floor, so I just ended up moving the bench.
The other thing I'm thinking about is that the *real* problem is the air cleaner sticking way the hell out there. I've been somewhat digging around for maybe a low profile cleaner, or even consider something that would move it forward
Be careful trying to move the pedal outwards or using a wider one on the stock arm. Putting the center of pressure outboard of the pivot point will put more offset leverage on the pivot bearing and arm. The bearing isn't much of a problem as long as its properly greased up but will begin to bind if it isn't. The arm itself may not be able to handle the extra offset torque load and flex reducing the pressure in the master cylinder and brake effectiveness.
A better alternative is to find or make a bracket that will move both of the stock pedal assemblies back a couple of inches like those used by the taller guys to move the pegs forward, just in reverse.
I don't remember where I saw it, but someone around here made up a set just like that for his bike. Maybe if you look around with the search function you can find his write up.
