Carlini Flying Apes
Went to Carlin today and got the 14" Fly'in apes and diamond risers. For anyone considering these bars I will tell you that they are beautiful. Be aware that they run approx and inch taller than there spec size. BUT... that said, it all depends on which Fly'in Ape model you get. There are two. One is a stepped bar to fit a standard 1" diameter riser and the other is non-stepped. The stepped bar, although also a fly'n ape, is completely different in looks. Comparing the two, it is 2" wider at the top and bottom . The bottom is also more squared... much like the Wild1 bars. It also is about 1 1/2" -1 3/4" taller than spec size indicates. They both have the nice curve though.
Good discussion for me to read. I'm planning on ordering the 14" Gangsters tomorrow. I'm putting them on an '08 Sringer SE. My only concern about these was the lack of knurling. Anyone had any problems with these slipping? I'll be going with the 1.25" non-stepped since my bike has the 1.25" risers already.
Mimo.
Let's hope not!!!!!!! I've searched and searched and I can't find anyone complaining about it. I wonder if they do that so they don't have to go to the trouble of managing different set's of inventories for different bikes (due to the different spacing)??? Time will tell us I guess. Mine should be on next week or the week after. I'll let you know if mine is disastrous!
Can't weigh in on the Carlini's slipping as I haven't put em on yet. I did have
1 1/4" beach bars on that weren't stepped/ knurled and had no problem. I played around with them a lot trying to get them at the right height and angle. Each time I had to loosen the risers bolts as there was no way they were budging while puching down or pulling up.. I know the apes are a different animal but don't expect a problem. The 1 1/2" Carlinis are huge. I was surprised at the difference bewtween the 1 1/4". The piston style risers that I saw for the 1 1/2" non stepped looked like frig"n hockey puck diameter.
Just an FYI, while I was at Carlini I saw what they consider a blem and it is insignifcant. Example: a 1/2" scratch at the bottom which would be facing down next to the riser. Well worth the discount IMO and puts them in the Wild1 price range.
