Carlini Flying Apes
Old Sep 21, 2008 | 05:31 PM
chromedome's Avatar
chromedome
Default Carlini Flying Apes
Have 12.5" Wild1's now on my Deluxe. Thinking about switching to a 14" or
16" Carlini Flying Apes. Occasionaly I use the HD quick detach windshield. Does anyne know if it will fit with the forward bend of the Carlini's?
Old Sep 21, 2008 | 06:09 PM
blz2503's Avatar
blz2503
Dont know the Carlini answer..but I d be intertesed in buying the Wild 1's
Old Sep 21, 2008 | 09:21 PM
BluBob's Avatar
BluBob
Those Wild Ones look great on that Deluxe! But, if you are set on swapping them, just draw a line up the vertical bends and add 1 1/2" or 3 1/2". If that line goes through your windshield then it won't fit with the new bars, unless you angle them back, and that would lower your grips an inch or so anyway.
Old Sep 21, 2008 | 09:52 PM
chromedome's Avatar
chromedome
blz2503- I'm going to check with Carlini and if it works out will selling the Wild1's. Also be selling the smooth wild 1 top clamp and risers since the Carlini's don't step down. You can have fisrt option.
BluBob- Thanks for the info.I wouldn't have a problem with having to rock the bars back on the occasion I use the shield. Would depend upon how much though. Will see what Carlini has to say about the fitment.
Old Sep 22, 2008 | 05:58 AM
jslamerman's Avatar
jslamerman
Just be careful on height. I ordered the 14" Gangsta Apes and risers (low rise), and Ill tell you, Im 6'6", and combined with the lower seat and lowered rear suspension, these bars are probably 3" above my shoulders if I slouch (I try and sit in "inspection ready" position on the base and around cops, its funnay. Looks like I have a rod rammed up my a##)
Old Sep 22, 2008 | 07:47 AM
mplecha's Avatar
mplecha
Also, just to let you know, Carlini doesn't make anything shorter than 16" high with the 1.5" diameter. I originally wanted a set of 14" gangster apes, but they don't make them in 1.5" diameter. Lucky for me, I got the 16" bars instead and couldn't be happier with them. Good luck!
Old Sep 22, 2008 | 11:25 AM
mimo's Avatar
mimo
Ask for Rex at Carlini,
Mimo.
Old Sep 22, 2008 | 05:33 PM
SniperCJ's Avatar
SniperCJ
The Flying Apes have the backward bend. Its the Gangster Apes with the forward bend. And yes, the QD windshield fits fine with my 16's.
Old Sep 22, 2008 | 09:27 PM
chromedome's Avatar
chromedome
I think I'll go with the 1 1/4" bars. The 14" bar is new.
Old Sep 22, 2008 | 09:30 PM
chromedome's Avatar
chromedome
It's actually the opposite... gangsters inward bend, flying outward bend. I like them both but favor the flying apes. I don't think the Gangsters look good in anything less than 16". Just my Opinion.
