"DYNO" Numbers For SOFTAILS
Old 04-10-2014, 06:50 PM
harleytuner's Avatar
harleytuner
harleytuner is offline
The operator should use the force scaling option when he prints the sheets. If the HP and TRQ line are scaled the same it gives a better representation of how the bike is performing.
  #992
Old 04-11-2014, 08:51 PM
ghoticov's Avatar
ghoticov
ghoticov is offline
Originally Posted by ghoticov
Just got my bike back from the dyno. I am floored at the results. It pulls sooooo friggin hard. Also, no compression releases... just using the 574 easy start crane cams and they work like a charm.
107" cylinders
No Headwork
574 Easy Start Crane Cams (Chris "Rocket" Rivas endorsed cams)
CP Pistons (10.75:1)
Big Sucker (extended filter)
Big Shot Staggered
PC111
I have an opportunity to buy a Pro Pipe 2:1 at a VERY good price so I am thinking about jumping on it. Do you guys think going with the Pro Pipe will get rid of that dip in my torque curve above?
Also, is it necessary to get the bike retuned after putting the new pipe on or could I wait a little while to do it?
Anyone have an opinion on this?
  #993
Old 04-12-2014, 06:34 AM
Lone wolf lo 10's Avatar
Lone wolf lo 10
Lone wolf lo 10 is offline
2/1 exhaust improve low end toque performace there's a good chance you will see a rise in toque at lower RPMS and just might help the dip
  #994
Old 04-13-2014, 07:21 AM
harleytuner
It will help the dip and YES you will need to get it tuned again.
  #995
Old 04-14-2014, 05:58 PM
groovna's Avatar
groovna
groovna is offline
Default New tune
Took my Rocker with the Hellraiser build back to Fuelmoto for some pipe testing and found some more power. Switched from a V&H 2 into 1 Big Radius to a V&H Pro Pipe. There are only a couple options out there that fit this bike with the diameters that we needed. Got 5hp and 4tq more peak and 8tq more early in the rpm's. New numbers are 126 hp and 131 tq. To compare, my original dyno sheet is post #852.
  #996
Old 04-24-2014, 11:21 PM
ghoticov's Avatar
ghoticov
ghoticov is offline
Dyno for the new set up:
107"
574 EZ start cams
Big sucker
V&H Prop Pipe Chrome
Direct Link tuner
And here is a comparison. I had a V&H Big Shot Staggered and a PCIII. So the only thing I changed were the pipes and the tuner.
  #997
Old 04-25-2014, 05:58 PM
DigbyHD's Avatar
DigbyHD
DigbyHD is offline
so u make slightly less top end but looks like you make more power where it counts... im still learning to read these things
  #998
Old 04-25-2014, 06:18 PM
ghoticov's Avatar
ghoticov
ghoticov is offline
Yea, lost 1 HP and a few torque. No way I would ever feel the difference in 1 HP. Lol
But I certainly feel the difference in the pull of the bike in the 2800-3700 range. Overall, it is smoother and the power is always there.
  #999
Old 04-28-2014, 08:55 AM
DigbyHD's Avatar
DigbyHD
DigbyHD is offline
That is exactly how i feel about my Pro Pipe.
Bike was stock when i got it and felt like a slug, had the dealer put on the Prp Pipe intake and tune it and now i have power in every RPM range- it never has loss of power!
If i keep it around 3k range it pulls the best tho.
Next i was looking at doing some mild cams like 255s
  #1000
Old 04-28-2014, 02:00 PM
Junker's Avatar
Junker
Junker is offline
I would love to see it retuned with the bss pipes.
107"
574 EZ start cams
Big sucker
Direct Link tuner
Quick Reply: "DYNO" Numbers For SOFTAILS
