"DYNO" Numbers For SOFTAILS
#1221
<a href="http://s79.photobucket.com/user/FUBAR-cvma/media/2016%20Heritage%20Dyno_zpsin0st3qg.jpg.html" target="_blank"><img src="http://i79.photobucket.com/albums/j128/FUBAR-cvma/2016%20Heritage%20Dyno_zpsin0st3qg.jpg" border="0" alt=" photo 2016 Heritage Dyno_zpsin0st3qg.jpg"/></a>
I got my 2012 Heritage back from Winter mods. Had the heads milled .030, mild port and polish, Arlen Ness Big Sucker w/Harley cover and RB Racing LSR 2-1 exhaust. The dyno sheet compares my 2014 dyno with my latest 2016 dyno. Would you guys please comment if it appears the mods I made are worthwhile? Thank you. I put the Woods 222 in before the 2014 dyno. My signature is before the mods. I haven't taken new pictures yet.
#1222
Did mine yesterday at Dyno Difference in Dallas. Ed did my Dyna several years ago and does great work.
Bike: 2013 FLS Softail Slim - 103ci
Mods: RSD Venturi air cleaner, V&H Big Radius w BCT Monster baffles.
Stock numbers: 72.7Hp@ 4687rpm / 95.8ft-lbs@ 2980rpm
After Dyno: 81.3Hp@ 4980rpm / 103.2ft-lbs@2832rpm
#1223
#1225
I-corps
Its looks like you got about what you should have.
most stg1's and cams will increase your TQ and HP by 10-15..
a good port job should be around 10 and 10. So you're right in there..
The 222's peak out a little later than I'd want, but I am old and ride a lot in the 2-3K rpm range and seldom rev over 4K.
Your sheet Looks like you can feel it pulling stronger and stronger all the way to 5.5k rpms.
#1226
#1227
2007 Fxstc build
2007 Fxstc
-- 107"
-- CNC Ported heads 1.9 & 1.61 valves
-- 585 Easy Start Cams
-- S&S lifters & Pushrods
-- 10.5.1 Pistons
-- Zippers Final Chain Drive Conversion
-- D&D Fatcat Pipe
-- Barnett Clutch
-- Big Sucker air cleaner
-- Stock Throttle Body
-- Dyno Jet Power Vision Tuner
-- Custom Paint - 57 Chevy Blue
Built by Kendal Johnson Customs
------ 118 Hp 123 Torque --------
-- 107"
-- 10.5.1 Pistons
-- D&D Fatcat Pipe
-- Barnett Clutch
#1228
Just had my new top end dyno tuned. 98 HP/102 lb torque.
2006 Heritage Classic
S&S 97 big bore kit
SE Pro CNC Ported heads
S&S 510 gear driven cams
V&H Big Shot Staggered exhaust
Power Commander III
SE Stage I air filter
I'm ok with the hp/tq numbers, but they come in at too high rpm. As soon as the funds become available, 583 ez start gear drives are going in
S&S 97 big bore kit
Power Commander III
#1230
Go with the
S&S 97 big bore kit
Power Commander III
S&S 97 big bore kit
Power Commander III
