Fat Tire Kit
either spend $3000 on a complete kit and go up to 250 or switch to chain or narrow belt and you can put a 200 on using your stock swingarm. anything over 160 you have to cut your struts and change your fender. anything over 150 and you have to go with an 18" rear to clear your caliper.... there are a lot of nice fat tire kits out there. from what i've been told any kit that doesnt require offsetting the entire trans is good... starting my 200 upgrade now myself. good luck. told these kits are good http://www.tejasthumpcycles.com/Part..._tire_kits.htm
Josh, you mentioned changing to a chain or narrow belt, do you know what size belt? I have an '05 NT and was going to go with just a 180/wheel & tire, but if I can change the belt and get a 200 I may go that way. Is there an DISADVANTAGE of a narrow belt vs. the one I have now???? Thanks!!!!
the stock '07 standards/trains/fatboys all come with a narrow belt (20mm) and a 200 tire stock. they run a 17" wheel but we have to run an 18" so we can use our stock caliper. my buddy has the skinny belt on his and he rides it hard with no problems. i just saw a screamin eagle at the dealer and he said they have no problems with the 20mm belts. the other choice you have is a chain. but then you have to put a sprocket in your trans, which isnt that hard. we did one last winter on my buddies custom electraglide so we could put a 180 on it. looks good with his open primary and bags...
So is the 20mm belt that is used on the '07 the same length for what I would need? I can just go to my local HD dealer and pick one up?
I thought about the chain, but I think the belt looks better(IMO)
Thanks again for the info!
