Can I Make my Turn Signals Manual?
For those of you not from England, and if you've been lucky enough to not have visited, the roads here IMHO are not really designed to work with these automatic turn signals. There are a few posts asking the question 'Can these be switched off or made manual somehow', but I can't find one post on this forum with an answer.
Every other post on this subject seems to end up becoming a debate as to whether these auto turn signals are any good or not and totally screws up the question.
So is there any way at all to let me press the button once to switch them on, and then press it again to switch them off when I want? I only ask because I had a moment today involving the clenching of a certain muscle group when some idiot driver assumed I was going one way and nearly had his passenger door modified by my ride!
I don't like my turn signals under the control of anyone or anything other than me and me alone, because one day if they don't self cancel when they should I could end up being knocked off by a confused motorist.
So is there some wire I can cut like on some other models, (I've got a rocker C by the way) or a plug I can unplug, or a circuit I can short etc?
Bucketass, I know that I can cancel them by pressing it again, but sometimes they don't self cancel, sometimes they do but only after about 500 meters. Sometimes they'll be about to cancel themselves, (unknown to me), and I'll press the button again but this will restart the whole cycle.
if it wasn't integrated in the module you could pull the auto relay out but you can't...
i see what your saying though.
Received 1,211 Likes
Easy fix if you're a wee bit handy. Score an old-fashioned flasher & socket. Then score a couple relays that will activate with a push of the switch, and deactivate with another push. Clip the wires to the turn signals a couple inches from the module. Clip the wires from the switches near the module, too. Add a "hot" wire and you now have all the wires needed to hook up the things the old way.
