2000 Softail Heritage Tires widest rear tire w/o mods?
Hi Guys,
It is time to get new tires for my bike. I'm running stock dunlops but I'm considering the Metzelers. My questions is: what's the widest size I can put on my bike without any wide tire kit or any mods...?
Thank you in advance and I apologize if this questions has been answered already...!
Al
Al
I went to the dealer and the guy in the parts dept told me that I had to go with stock ones...! Then I asked one of the service guys and he said that it was impossible to put anything wider than stock...! :-(
What kind of kit did you get from the dealer Hawgman?
Thanks guys for your comments.....!
Al
Al
Solution to my question.....!
Hi guys,
I did a little more research, and found this web site where they list the max tire size you can put on your bike w/o any mods....!
Just passing along some helpful info....
http://www.hdwheels.com/Product.htm
Take care,
Al
Take care,
Al
Stag (01-13-2024)
On an 03-06 fatboy the wheel itself is offset to allow a 150mm tire. I think before that it was a 130mm tire. merely measuring the width of the fender for clearance will not tell you the width of the tire you can use. The offset of the rim is the main factor. looking at a chart for an aftermarket rim would not be accurate because a rim offset for a 1500mm tire would work with a 130mm tire but not the other way around.
I wouldn't go any wider than recommended from the factory. the wider you go, the more the tire deforms to have to fit the smaller rim, causing the tire to alter the profile that was intended by the manufacturer. this causes the tire to make the bike handle differently than was intended. Obviously, a wider tire slows down steering but one that has a tire that is too wide for the rim can wear down in a way not intended which will also cause even more unstable handling characteristics down the road; worse case scenario, it can cause complete tire failure, not something that is very pleasant.
