I need help with a Rocker c ?
If you only want to lower it 1" then any of the bolt kits like HD, Arlen Ness, Burnout Cycles would be fine... I think the ride with a bolt kit sux *** when you slam it though cuz you're always on that big bump stop on the Rocker.. If you were going to slam it then I recommend the Progressive 422's.. That is unless you like riding a rigid..
Ness kit is adjustable as are the others if I'm not mistaken. Once you install the kit...you can lower the bike however much you want. I have the Arlen Ness kit and mine is only lowered 1".
Arlen Ness part # 17-100
Ebay for $57.00
[QUOTE=RockerDave;4140574]I don't know that there is a kit that lowers it just 1". However, the Arlen
Ebay for $57.00[/QUOT
do you have any more pitcure of your bike lower 1' and did you make it only 1' inch ? how did you set it for only 1' inch ?
