Mounting a factory set of Rigid Leather Roadking bags on Fatboy
What would be the best method?? I love the lines of the factory Roadking Custom bags (probably not the biggest damn bags because of shock cutouts, but.......), Ive seen the cycle visions mounting, not exactly the prettiest, and the Bubbas bags (my favorites so far). Could I just use some other generic system to attach them to my existing quick release mounts?? I want to do this right the first time, considering the purchase cost of bags, and now an exhaust that will allow use of these (probably VH sideshots). Ive got a widetire 2007 version, with lots of mods so it was either this, or a new 2009 streetglide (couldnt bring myself to part with it after installing an HD inverted fork, a set of 52 spoke DNA mamoth rims, including a 21x3 front). ANY help would be appreciated. Id also like to be able to remove them without a lot of ugly hardware if possible, if not the best looking permanently installed look (and hopefully somewhat cost effective)
Those are exactly what I am looking for......but, I have detachable harware for both a detachable old school 30" sissy bar, and for a rear rack (ala harley davidson with detachable side plates, and relocated turn signals). I am assuming this stuff is incompatible?? The turn signals dont bug me (I like how they relocate them to the plate bracket), what about the other stuff I currently have??
I dont think the Easy Brackets are a good choice for bags as large as Road King bags. You need some additional support lower on the bags due to the size. With the larger bags you get a lot of wiggle with only the EZ Brackets.
I have EZ Brackets on my Osprey bags that are 21 x 8 x 13 and I dont think I would want to go much larger or heaver with only the EZ Brackets.
You have to use a kit like the cycle vision or similar for the support bars that run under the bottom of the bag. Dont try hangin those heavy bags on just the strut mounts like smaller bags are mounted, your just asking fot troubles.
Here is another style
http://cgi.ebay.com/ebaymotors/Harle...Q5fAccessories
I have a set of Road King Custom bags and a set of easy brackets that I was going to put on soon. Are they really too big and heavy for the easy brackets? I don't want them permanently attached and I will only use them once in awhile. Has anyone on here seen them mounted with easy brackets? Any pics??
Well, this officially stinks. I thought there was a cleaner way to mount them without cluttering the rearend with the cycle visions stuff. Even with their painted inserts, Id still have visible bracketry behind me, and I wouldnt be able to remove the bags. Id have bought a new Streetglide instead..........
