Difference in wheels
Ok fellow forum writers, readers and a few of you who know their stuff.. On its way my frontend 58mm Ultima inverted.. I will be installing it on a 08 Rocker, the actual install is pretty straight forward.. This front end is intended to be used with the 84-99 FXST wheel and caliper, the caliper I beleive i can get/make a bracket to make it work with the current caliper....Here is my question, how different is the 84-99 FXST wheel to the rocker? from what ive read same size and width but that is pretty much all i've found.. Im hoping MOCO went retro and its the same wheel, but I know im not that lucky.. Any Info Thanks...
Check with HD you may be able to get a bearing kit for the wheel that includes the bearings and spacer you need. When I replaced the wheels on my RK they came without the bearings and I just ordered the kit I needed to fit the axles I have on the bike.
As for the caliper bracket you may be able to modify the bracket for clearance for your caliper if the mounting holes are the same distance apart as the 84-99 calipers. I think the demension of the rotor may be a problem more than the caliper. The 84-99's used a stock 11.5 inch rotor what diameter are yours?
Does the Ultima inverted have a 1" or 3/4" axle. I am assuming 3/4", you're Rocker has a 1" axle and a narrower front end, more like a mid glide so you will need to space out the rotor also. The 2000 up calipers wont bolt up as you know, so you need either an adapter bracket or get an earlier style caliper. You used to be able to get the caliper adapters but I can't find them anymore. The MoCo also changed the rotor diameter from 11.5" to 11.8" in 08 I think, so you may have to get a new rotor. I went through this on my 04 Train.
I will double check the diameter of the rotor. The diameter of the axle is diffrent so im prepared for that change.. If I cant find the caliper bracket, i will see if i can fab one up, but wont know until the front end gets here, tracking shows saturday... Thanks for the info anything else you think I might run into shoot me an email or pm.. Thanks
How did/does the front end handle any problems with it? I ordered it with 5* rake.
J&P has an inverted front end brake caliper mounting bracket part number 242-513 it's for softails and dyna's and FXR's so it might be a universal adapter you can make work. they also have spacers for the rotors to move them out far enough for the new wide glide front end your installing.
You might also ask HD if they have a wide glide kit with the spacers you need to set up the new front end. They probably do since their selling the new inverted front ends now.
Make sure when you mount the new bearings and spacer in your wheel that you have the proper end play so you don't burn up the bearings.
