For the Crossbone and Springer owners
Old 07-07-2009, 03:14 PM
travis dasher's Avatar
travis dasher
travis dasher is offline
Default For the Crossbone and Springer owners
Has anyone taken the shock absorber off of the front of the springer front end? I have been thinking about doing it but am curious about the ride. Most of the old school springers dont have the shock absorber, so just thinking.... If the springers of old rode fine without them, would good logic be that the new springer front end would ride fine without it? But I know since it is there it must be there for a reason.. Just thinking out loud and looking for a few opinions from you guys. Thanks
Old 07-07-2009, 04:58 PM
Zacharia_11's Avatar
Zacharia_11
Zacharia_11 is offline
You can get them with or with out in lots of aftermarket springer set ups. What would you do with the mounting tabs? I think they might look a little funny with out the shock in them.
I am swapping mine out for a black one so it doesnt' chrome up the joint to much...
Old 07-07-2009, 09:05 PM
travis dasher
I thought about that, if I like it then I can install the RSD headlight bracket relocation with a spacer in between the mounting tabs and a different bolt. Or drill out the bracket and mount it in between the tabs. The other mount I can use another spacer or hack it off. Dunno havent made any exact decisions about it yet, just more of a thought than anything else. Thanks for the reply though.
Old 07-07-2009, 09:10 PM
man4mopar's Avatar
man4mopar
man4mopar is offline
You can do it sure. The ride will be more of a glide feel and will hop/pogo more. The bad is the front tire is more likely to cup due to the front wheel hop (pogo feel).
Old 07-07-2009, 09:33 PM
Zacharia_11
I was thinking the same thing, if you could just fill in the gaps it would probably not even be noticable. Blacked out nut(s), spacers or small pipe would probably do it. Wouldn't be much to take it out for a week or two, snap a couple of pics and take a few rides to see how it feels.
Old 07-08-2009, 08:15 AM
Cheesecake's Avatar
Cheesecake
Cheesecake is offline
Keep us up to date on this....
I thought about doing it... but was worried about the handling
CC
Old 07-08-2009, 09:47 AM
xraybox's Avatar
xraybox
xraybox is offline
The pre shock era springers used adjustable sliding plates to control the "pogo" effect
Old 07-08-2009, 10:34 AM
97FXSTSB's Avatar
97FXSTSB
97FXSTSB is offline
I think it would look funny without the shock.
Old 07-08-2009, 10:54 AM
jrjones's Avatar
jrjones
jrjones is offline
I took the shock out and rode it down the road. I really didnt like the feel. I had that pogo feel to it. It doesnt take long at all to take out, so pop it out and try it. That is what I did. As for the RSD headlight braket it is designed to fit a Headwinds headlight not the Harley headlight. It will work just need some washers and rubber bushings.
Old 07-08-2009, 11:22 AM
travis dasher
Thanks for the reply's. I think I'll give it a go and post what I think about it. Thanks.
Quick Reply: For the Crossbone and Springer owners
