Heavy Breather on a FatBoy?
Old 09-04-2009, 01:59 AM
PKellyMc's Avatar
PKellyMc
PKellyMc is offline
Location: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Default Heavy Breather on a FatBoy?
My boss was told he couldn't put a Heavy Breather on his '01 (carb'd) FatBoy. I told him "Never trust parts counter guys or HD catalog fitment claims", and that I'd ask the experts. So does anyone have one, with a picture or two I can show him? Also, the p/n of your HB? Thanks, from the Dyna side of the house.
Old 09-04-2009, 08:11 PM
PKellyMc's Avatar
PKellyMc
PKellyMc is offline
Gratuitous bump.
Old 09-04-2009, 08:29 PM
flstf08's Avatar
flstf08
flstf08 is offline
Go to www.jpcycles.com "air cleaner" section they have many. As far as Best
that is up to him and his pocket. K&H filters are good.
Old 09-04-2009, 10:24 PM
DoobieBrother's Avatar
DoobieBrother
DoobieBrother is offline
Why not? It's the same 96 cube motor put in every other softail.
Old 09-05-2009, 07:57 AM
aviator's Avatar
aviator
aviator is offline
??? wasn't it an 88?
Old 09-05-2009, 10:20 PM
DoobieBrother
`01. Sorry. Regardless...
Old 09-05-2009, 10:32 PM
oct1949's Avatar
oct1949
oct1949 is offline
should probably almost might be able to find one.
Old 09-11-2009, 09:34 PM
harleyheaven's Avatar
harleyheaven
harleyheaven is offline
I've got a Screamin Eagle Heaver Breather off a 2005 Fatboy if you want to give it a try.
Old 09-12-2009, 04:55 AM
hpfatboy's Avatar
hpfatboy
hpfatboy is offline
Check out www.bcheads.com TOP right corner of page, picked up good numbers with this!!! You can also put cover over it if you want, like i did.
Old 09-20-2009, 04:27 PM
MC-03-FatBoy's Avatar
MC-03-FatBoy
MC-03-FatBoy is offline
3rd Gear
PKellyMc,
Did you get your answer yet? I am wanting to put the Heavy Breather on my 03 FatBoy, but I am not sure if the throttle body is 50mm, I thought it was only 48mm. Any info you have found will be helpful, part numbers, or anything. Thanks
Quick Reply: Heavy Breather on a FatBoy?
