Guys can someone with the Willie G foot pegs for the Rocker post the part/number for the pegs you ordered. I have spent most of the evening looking for this part with conflicting information from HD.com and ebay sites with regards to compatibility with the Rocker. At the point now where I actually need to know what worked for you guys.
Thanks
NewfieRocker
You would think HD would be on the ball with there fitament??
So the Willie G pegs will fit the Rocker, there appears to be only one style with a male mount.
Any other readers I would appreciate you input as well.
All the foopegs fit the Rocker. Because the Rocker sits so low and the pegs are more likely to drag, HD claims they don't fit, so they're not liable if anyone has a problem because of pegs dragging.
Hell, they cant drag much worse than the stock ones with the big tit off the bottom. I am going to grind that tit off mine with a grinder i think so the pavement doesn't do it.
