oil filter stuck
Old 03-12-2010, 07:00 PM
mtairy biker's Avatar
mtairy biker
mtairy biker is offline
+ 1 for the strap wrench I got mine at NAPA
Old 03-12-2010, 07:05 PM
luvtoride's Avatar
luvtoride
luvtoride is offline
Thats why you hand tighten an oil filter, and not really that tight either..snug will do it. Good luck with it
Old 03-12-2010, 07:40 PM
In Memoriam Citoriplus's Avatar
In Memoriam Citoriplus is offline
May our Moderator Rest in Peace
I have never had a problem getting one off my bike.
But its not uncommon on cars and when I find one like that I use a screwdriver either through it.
Or put a flat blade on the bottom lip edge (inner part) and bang on it with a hammer.
It should dig in to the folded edge rotating the 'can' counterclockwise and off.
Old 03-13-2010, 12:14 AM
bmr's Avatar
bmr
bmr is offline
Insert screwdriver through side of filter with a hammer then twist, repeat if necessary. Caution: hammer + paint = pissed off.
Old 03-13-2010, 04:24 AM
bobbyd3's Avatar
bobbyd3
bobbyd3 is offline
Jam a screwdriver through it and then you have handle to give you leverage to turn the filter off.
Old 03-13-2010, 07:31 AM
tk353's Avatar
tk353
tk353 is offline
i used a 10 in screw driver and punched a hole in one and it came loose. messy but got the job done.
Old 03-13-2010, 08:14 AM
aviscomi's Avatar
aviscomi
aviscomi is offline
I had this problem on my Ultra...take the Cooler lines & Colooler off to give you more room for leverage. Beware its messy!
Old 03-13-2010, 08:32 AM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 18,477 Likes on 5,455 Posts
I haven't had to use a screwdriver or strap wrench since I bought a pair of these
Lisle LIS50750 2-1/4 to 4in. 20 Degree Angle Oil Filter Pliers
Overview - Compare prices
$4 new from 42 sellers
Slip Joint Handle for Greater Range. Two-position, slip-joint handle produces the range of three separate conventional filter wrenches. Overall range 2-1/4" to 4". Jaws are bent at a 20° angle to fit more applications. Sure grip teeth prevent slipping. Cushioned handles provide comfort.
Add to Shopping List
Old 03-13-2010, 09:19 AM
TexFordD's Avatar
TexFordD
TexFordD is offline
JD you get it off? I like the screw through the filter cap but I'd use 2 . Removing the cooler would be a last resort considering the hoses will probably tear when you pull 'em and then you'll have 2 issues 8(
Old 03-13-2010, 11:29 AM
jd8181's Avatar
jd8181
jd8181 is offline
i'm getting ready to head to sear to get a new strap wrench (mine was a craftsman that broke so they better replace it for free) i'm going to try the strap wrench 1st (but with the oil cooler i'm not sure it's going to work) they probably try drilling 2 little holes in the oil filter cap and put 2 screws into the cap into the filter itself. i really like that idea. i'll let you know what ends up working.
Quick Reply: oil filter stuck
