Dyna beads 21 x 3.5 rim and tire choise
I want to install a 21 x 3,5 front fat spoke rim with a with wall tire on my Deluxe. Now i heart that some oversize a tire with a tube and the use of Dynabeads. Can you help me with the brand for the tire and how much weight was added with the Dynabeads. Or do you go for a 21 x 3 rim?
Thanks Paul
Thanks Paul
I am not quite sure what you are asking but I'll try to answer.For a front tire 80-120 mm (width) you use 1oz of dyna beads.For a rear tire 130-240mm (width) you use 2 oz's of dyna beads.I just installed some on my 2010 Deluxe and they work great I will never go back to regular wheel weights again.As far as the tire goes (white walls)biggest is the new Vee rubber 120-70-21 if you can find it.Or you can stretch a 90-90-21 Avon Venom WW or Metzler 880 WW over whatever rim you buy.But if you go with a 90-90-21 tire I would not go with a 3.5 " width rim.I would go no wider than a 3" rim.Even that is really strecthing the tires limits and it is not recommended by the tire companies.Plenty have done it on here with no problems but a 90-90-21 tire is meant to go on a rim no wider than 2.15" as per the tire companies.
The dyna beads website will tell you what you need for your tire. I have used liquid products in the past, pre-dyna bead, and they also worked great, but they seem to no longer be acceptable. Dyna bead is a dry product that performs as a fluid irt to wheal balance, but without the tire market complaints. OH, they will still not like them, but have absolutely no greivance. They can even allow a bad design to run properly, the tire companies should adore them.
