FXST won't idle, warm, without enricher pulled out a little
My recently purchased 2004 FXST seems to be in pretty good shape, but it absolutely won't idle, no matter how warm, without a little extra gas from the enricher or the throttle. I have put a couple of hundred miles on it and it's cold and wet here now, so I'm thinking of doing some adjusting.
Looks like it has a Screamin' Eagle air cleaner and it has Samson pipes that are a straight pipe with no baffles.
My first thought is it needs carb adjustment to account for the air cleaner and lack of back pressure from the pipes - some people say they never run good with straight pipes, so I might go with some baffles.
Any thoughts on the likely cause and solution?
Heres one I found on how to tune her.
http://www.harley-performance.com/ha...arburetor.html
Heres the same problem other members has had..
https://www.hdforums.com/forum/engin...wont-idle.html
Hope something in here Help Ya....OCT1949
Hmmm -- my bike won't idle (especially in the winter) on a cold start without pulling the enrichener either. After about 60 seconds and a few pops on the throttle, no problem. I figured it was the nature of the carbureted beast and it never occurred to me to mess with the idle adjustment. Maybe I should (great link on the carb adjust oct1949, thx)
thank you,
JR
your engine is lacking in fuel, that is why it will run with your choke pulled out. you are in need of a carb rejetting. i used to run a 190 main jet with the Big Guns in my bike but could have used a 185. if you are not familiar with changing jets there are many shops out there that can help you out. you will be surprised how well it will work for you.
thank you,
JR
thank you,
JR
