Primary Oil Change Question
2004 Softail Springer...changing oils myself for the first time. Should have started this loooooong ago!!!
My question is...I refilled the primary oil based on what the service manual says. It states to put 26 ounces in and I should see it just at the bottom of the clutch plate. Well,
I have put about 28 ounes in and I do not see it at the plate. Honestly, it looks as if a lot more oil could go in there.
Shoul I go by the ounces or should I go by the visual and keep adding until I see it on the bottom of the plate????
Ran into the exact same thing. My service manual says the same thing and includes picture of what you are talking about. I thought the same thing after putting in the recommended ounces. This may not be the same case for you, but in my case, I had to go back and look at the picture a few times. When looking in the opening, my first thought was that the level was supposed to come up to the bottom of the plate that is easily seen. If you look at the picture in your manual, it is actually below that. You have to really look down in to see the one the manual refers to. I dont think a few extra ounces in there will matter, but you definitely dont want to overfill too much. Hope this helps. Not a very good description, but just pay real close attention to the picture in your service manual and it will make more sense to you.
Is your bike exactly level when looking in the hole?
Should be barely touching the bottom edge of your clutch spring.
Don't put no more than that 28 you already have in there.
My 04 softail was fussy like that. Didn't shift as smooth when I ran more than that.
The newer bikes have higher capacities.
