1/4 fairing on a softail
Old 04-18-2011, 07:01 PM
sledhead140's Avatar
sledhead140
sledhead140 is offline
Default 1/4 fairing on a softail
will a 1/4 fairing from a wide glide II work on a night train? it would be the same front end. i can't find a listing anywhere for a fairing to fit a softail or a dyna wide glide. a friend of mine has an 02 wide glide II and it looks like it'd fit on my train.
Old 04-18-2011, 08:35 PM
MCSarge's Avatar
MCSarge
MCSarge is offline
Most are generic mounting, you get the fairing and then make up your own mounting brackets. They sell them for wide and narrow front forks.
Old 04-20-2011, 04:35 PM
sledhead140
oh ok didnt know that. i was just going by the harley parts catalog
Old 04-20-2011, 05:12 PM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
Buy a fairing and use turn signal relocation brackets to mount the fairing to the bike. I can get you both.
The one thing to be concerned about on a train is the height of the bars as one customer of mine said the bars where in the way when turned to either side and hit the fairing. I think the got bars with a little more pullback to solve the problem.
Drew
Old 04-20-2011, 07:03 PM
sledhead140
Drew, No problem here, im running 16in apes with a 1.5 inch riser
Old 04-20-2011, 08:08 PM
MLWilson's Avatar
MLWilson
MLWilson is offline
Here is a pic I found while surfing, it's on a Duece tho
Old 11-06-2011, 11:43 PM
KaotiK TrendZ's Avatar
KaotiK TrendZ
KaotiK TrendZ is offline
sledhead, you get any further with your setup? i have a nightrain and looking to put a fairing and then some type of audio setup under the shield.
MLWilson, where did you find that first pic of the deuce? it looks like he might have his sitting a little further back and wanted to see if i can find more pics of his setup. thanks.
Drew, shoot me an email on the same fairing like the first duece pic that MLWilson posted. I assume i might need the brackets too. if you can send me a price on each item separately that would be great. i am also looking into a few more items. i will be in your system already from buying other items.
Old 01-23-2016, 11:05 PM
Mad12c's Avatar
Mad12c
Mad12c is offline
Stage II
Default 03 Night Train Arlen Ness Fairing
So I just added the Arlen ness fairing to my Night train. I made my own brackets and also painted them, and used the holes already on the triple t up on the forks. Just had to buy bolts which were very cheap. I relocated my turn signals from the top of the lower T to the bottom. That was easy! Then I just had some help holding the fairing in place so I only have to drill one whole in the faring. Everything came out great. I just got the headlight extender block to push it flush with the fairing but I will have to rig up some wiring because the it was long enough for the 2 in block extended headlight. So that will have to wait. It does make a difference when riding. The wind is not as it use to be without it. And people seem to like how it looks. I personally didn't think it would look good as I did it for the purpose of blocking the wind. But it has grown on me. I took pictures of the progress....
Old 01-23-2016, 11:08 PM
Mad12c's Avatar
Mad12c
Mad12c is offline
Stage II
DOTR 35
10-26-2018 06:49 AM
02hdwg
03-31-2017 06:15 AM
Repoguy
04-02-2015 10:41 PM
Kapper1x
05-12-2013 12:41 AM
FXSTB Rider
06-19-2011 10:37 AM
Quick Reply: 1/4 fairing on a softail
