FXCW rake job
11-29-2011, 11:06 PM
Not sure if you posted the right link to the trees because those are for 41mm tubes Rockers have 49mm tubes.
11-30-2011, 03:10 AM
I was actually planning on going with the wide glide front end. I was pretty sure it's 41mm but I've been wrong before. But I wasn't too worried about it because it's all getting replaced. I just was trying to get all my specs strait with the rake and travel because it's a little confusing to me. I was basing the rest of the front end around those trees.
11-30-2011, 03:16 AM
Pretty sure HD100 went with different trees for his wide glide front and stayed with the 49mm tubes.
11-30-2011, 07:10 AM
with 5 degree you will be fine.
11-30-2011, 06:19 PM
It is my understanding that the rocker has 36* frame rake and 0* rake on the tree...
RJ
11-30-2011, 10:26 PM
Brochure says Rake Steering Head/Trail 38* / 6.20 in. I think I have seen other places about a 36* rake in the fame, so I assume 2* rake in the trees.
12-01-2011, 12:35 PM
Quote:
Originally Posted by
Kowan
Yes Kowan, you're right, with the Thunderbike trees you can use your stock 49mm tubes.
The trees have a 3° rake.
Just check out their website.
http://issuu.com/thunderbike/docs/ha...idson-parts/85
73TA
02-21-2017 04:06 AM
Kevin714
05-03-2013 09:16 PM
mtnlvr
01-10-2009 12:49 PM
Grendel UK
27
04-05-2008 05:14 PM
Rich Train Driver
16
03-24-2007 04:15 PM
225 ,
bars ,
drag ,
fork ,
fxcw ,
harley ,
interchange ,
kit ,
lowering ,
rocker ,
rotor ,
springer ,
tree ,
tube ,
wide ,
windshield
