rear pulley 06 to 07 night train???
Old 01-02-2012, 12:24 PM
dbrown5's Avatar
dbrown5
dbrown5 is offline
Default rear pulley 06 to 07 night train???
will a 06 night train rear 70 tooth pulley fit a 07 night train. the 07 has the 66th rear. the 06 is the 5 speed and 07 6 speed. has anyone done this? or is there another bike that has the 70th rear pulley that will bolt right up to the 07 night train?
Old 01-02-2012, 05:36 PM
jakazz's Avatar
jakazz
jakazz is offline
yes.....but will effectively lower the gearing....better torque on launches
its a 20mm right?
Old 01-02-2012, 06:13 PM
Tx_Outlaw's Avatar
Tx_Outlaw
Tx_Outlaw is offline
Both are 20mm
Old 01-02-2012, 06:26 PM
FadeToBlack03NT's Avatar
FadeToBlack03NT
FadeToBlack03NT is offline
So a 66t from a 2007 will fit a 2003 that came with a 70t? Correct? Will effectively lower cruising RPM on the freeway?
Old 01-02-2012, 06:40 PM
vulcanater's Avatar
vulcanater
vulcanater is offline
FadeToBlack, the belt on your '03 is wider than the pulley from the '06 and up.
Old 01-02-2012, 08:12 PM
Tx_Outlaw's Avatar
Tx_Outlaw
But he can still run at narrower belt......
Old 01-02-2012, 08:16 PM
vulcanater's Avatar
vulcanater
True that Chuck. A little more involved than just changing the pulley though.....
Old 01-02-2012, 09:40 PM
Tx_Outlaw's Avatar
Tx_Outlaw
If he installs a lower tooth count pulley, he'll need a shorter belt anyway....... Might as well go all the way.
Old 01-02-2012, 09:57 PM
vulcanater's Avatar
vulcanater
Yep.... I have just about everything except the belt, to put a 200 on the back of mine. But I've about decided not to do it.
Old 01-02-2012, 11:01 PM
dbrown5's Avatar
dbrown5
dbrown5 is offline
i found some 70tooth 06 NT pulleys on ebay for a lot less than a 07 after market will run me... the 06 is a little wider i think but it shouldnt matter the belt should center and ride there?
Quick Reply: rear pulley 06 to 07 night train???
