Determining Cable lengths
Carlini's run a little taller so the 16's are 17.5" if im not mistaken. Then you have to factor in your risers 1.5 or 2 and you will be at 18" or 18.5 .I'm sure you know you'll have to switch out your risers also. You should be ok with +10 cables but you might want to ask Carlini when you order your bars. I just installed 18's (not carlini) on my buddys bike and he went with +10 and had enough cable. I'm sure someone with 16 carlinis will chime in.
Yeah we went +10 on all cables, the front brake cable was a couple of inches long but we routed it to where it worked ok to give him enough play. Change out your riser bushings also, with taller bars you get more leverage so you want to elimenate any movement in the bars and risers. I used Good n Tight brand bushings on my buddys ride. Here are a few pics of my buddys whip, which used to be my old 06 now he owns it.
